9x16, et15 would they fit??
Was just wondering could I put that kind of wheels on Fabia? Wheels would be Azev A's, and rubber 214/45/16. Will they fit?
:eek: 9" !!!? Sounds extreme. :D I say offer one up to see - The offset is miles out from recommended with a 7.0 wheel, but with a 9.0 wheel might be ok? :)
I think they would hit the front struts, but as Jason says try one.
Please be careful as Azev have stopped making the A in 9x16 et15 in 5x100 due to cracks appearing as i wanted them for my mk3 vr6.
Got a set of T's (9x16 et15) instead with 195/45/16 tyres.
You should have no problem with touching the strut but your tyres will be past the arch.
Stretching the tyre just get's it under the rear arch.
Ok, they might be too wide. Have to see, if they are still awailable on January, when I get my car. One matey is selling a set.
Monkey boy: Would you say that 205 is better tyre size for those 9'ers rather than 215??
___________________________
going for that german look :rofl:
I wouldn't TBH. The standard wheels appear to be set quite wide at the front due to the way the bodywork/bumper swoops inwards at the front.
IMO you'd need a wide arch kit to get it all to work properly. For 9" wheels, you should be looking at 235 width rubber as a minimum.
J.
Most people run either a 205/40/16 or a 215/35/16 but i have seen a 195/40/16 put on but a bit small even by my standards.
Does anybody on here have any deep dish wheels on their fabia. Forgot how good these styles look
10mm more on the inside and 54mm more on the outside and 215 tyres will be too stretched
Use this site to work out offsets remember that std. Furby vrs is ET37 and 6.5" wide http://www.1010tires.com/WheelOffsetCalculator.asp
Yep, I know what standard is... I was just wondering, and streched tyre loooks so sweet :thumbup: Well we have to see, when I get my fobia :D
