Engine codes
Hi just a simple question if a faulty injector has been replaced and the fault code hasn't been cleared will the car run the same as when it had the faulty injector in it might sound daft but am curious to no many thanks.
no expert but I suppose the ECU would stop fuelling to a duff injector if a fault was registered. Could be a good idea to scan again and clear then scan again.
