Can't work out what I need for Bluetooth
I have a 2015 roomster se which came with the bob basic swing radio
Switched that out and put in a rcd510dab unit but don't know what I need to buy to get Bluetooth
I don't have maxidot or steering wheel controls big do receive a good few calls while driving
I keel seeing Bluetooth modules on here but not sure if that's all I need and which one to get
Thanks In advance
5k0 035 730 d or above or 7p6 035 730 j or above should work without maxi dot via the head unit with all phones (using HFP). Just check the head unit is compatible with BT as I am not familiar with it.
Feel sure it is compatible not sure how to check for sure though any tips ?/
Thank you BTW
Is it touchscreen and does it have a phone menu?
Touchscreen yes
Phone menu I'll check tomorrow
Sorry for the delay
Head unit does have a phone button on it but nothing happens when I press it
It sounds like you just need to add the module (with a loom and mic) as I described. They often come as a package on ebay.
So on your initial post you stated
Are you referring to the letter at the end of the part no
Ie 5k0 035 730 e would work ??
Will I need my vcds to code it or is it plug and play
Yes the suffix letter so e will work too. It will in theory need adding to the gateway installation list (module 77) and also some coding of module 77 although the coding is really just control of a few basic options to cover the way the phone book displays on the HU given you don't have maxidot etc.
cool thank you
