Dashboard Rattle
This is driving me bonkers!!!. There is an annoying intermittent rattle/sqeak emanating from behind the dashboard (just down a little and to the right of the steering wheel). If you push and hold the dashboard it seems to stop but this ain't a permanent solution!. Any ideas or has anyone experienced anything similar and have the cure?.
Not a clue, you could just undo some screws a bit, jiggle everything around and tighten 'em up again - that might work! Actually, it could be the wiring harness that goes to the fuse box, thats behind there - or the fuse box itself - its only screwed to the inside of the dash where it meets the drivers door (could be a bit loose?) or the headlight switch wiring??
