Intrior lights
When I use the middle setting, the lights just stay on, even when driving.  They did work OK for a few days, but now just stay on and I don't want to wreck the battery so I turn them off.  Irritating.
Any ideas?
Just seen the topic heading - should be INTERIOR lights of course!
Edited by twoladies
There are 2 buttons either side of that 3 position switch, are they in the up or down position?
The lights are individually switched on with those, they should be in the up position for the lights to be in auto.
Thank you Urrell.  Will give that a try!!
Check the boot and doors are all shut properly - mine wouldn't go off because the boot wasn't quite latched down! I could see the car diagram on the MFD but the choice of white fill on white outline to show the back window as open wasn't particularly obvious... :)
Has been mentioned a few times on here and I think nearly every time it has been the hatch not down properly.
Not at all obvious to me either.
Nope, it was the funny switches on either side!  Pressed the top of the switches and that did it!!  Result!!
Thanks everyone - if it happens again, I will know what to do - if I remember :D :D
Think I've seen the light now
