Illumination Control
Okay, my new project, Felicia Lxi arrived on my driveway with no stereo and no fag lighter! Just one negtive and one positive wire taped to the ariel lead. After two hours I got my JVC head unit to wprk but in a very dodgy way. One live split into two wires onoe neave splt three times and some realy bad, old speaker cable. As I have no centre consolse The wires all hang down into the passenger footwell and cut out once once or twice an hour.
Point one: Where is the best place to wire in the dash illunmination wire?
Point two: Can I run the light for the ciggy lghter from the same place otherwise its always on?
Point three: Should I have a centre console!?
I would appreciate any input recieved as I intend to get the inside of my carsoted before I tackle the body and engine. :confused: :confused:
7258.attach
7259.attach
Not 100% sure here, but if you already have an ISO block in the Felicia's wiring loom, pin 6 is the light-switched feed. You can also use this for the ciggy lighter.
It may be grey/blue colour
See here
For the ciggy lighter, you could always use a switched 12V feed from the ignition.
