any one else running wheel spacers
I'm going to purchase some tmorro for my le. Just lowered it so now want to bring out the rears and front a bit .going fir 16mm rear 10 mm fronts .what's other people running . Pics if any
12mm hubcentrics at the rears.  nothing up front.
lowered on eibachs.
Edited by JR RS
Do you have to get longer bolts?
Yes I'm sure you have to mate
u certainly do.  mine came with the spacers
if u don't, expect to c ur rear wheels snap off and roll down past u and injure someone or hit something!!
Edited by JR RS
Lol!!
Where get them from as your sits just how I want mine too!!
depends on the spacers you use! some bolt straight onto the hub and then you bolt the wheel onto the spacer
lowered on eibachs.
What did you use to combat the camber when lowering it? my rear inner edges keep exposing wires with the outer looking like new =/
nothing - its the stock camber settings.
its only been dropped 20mm at the rear - i have no issues with rubbing, even fully loaded.
How do you know what size spacers to put on . Have you lowered it and measured the distance from the body work ?
nothing calculated when i got mine - i just did some reading on forums like this, and the general consensus was either 12mm or 16mm, when lowered.
16mm was more prone to be problematic with the body work, especially the more lowered the car is.
with 12mm spacers and only a 20mm drop, you are very very safe.
