Hi,
Does anyone know if the Front Panel Is Bolted or welded. Mine has light accident damage and would like to replace. can anyone recommend parts supplier new or used. Regards Gordon
I am sure it is bolted if you lift your bonnet and look along the wing line you will see the bolts if I remember.
Thanks Danny......I've now seen upper mountings. if anyone is aware of the lower fixings I would be most grateful. Gordon
Open either of the front doors, look in the now visible forward door shut and you'll see the upper wing bolt, so I presume the lower one is, well, lower?
many thanks for your replies .yet another project .Gordon
