cruise cntrol
Hi all,
Ideas please, I have a 2007 2.0 ltr tdi auto estate, and my c/control keeps knocking itself off. When engine has been turned off and on again the amber light will re-appear, and all ok.
Once when on a motorway in c/c it just switched off whilst driving!!
Thanks in anticipation for any advice.
Any other warning lights or problems i.e. traction control?
Is switch ok? Some can get abit groggy and need a clean with contact cleaner
Or re-soldering the connectors, as (both) has been mentioned numerous times, for a more permanent solution.
Edited by Tilt
Hi all,
Search :- cruise control on this forum.
It has been covered loads of times mate. (I see you are a newbie).
Should give you a good insight into the probable problem.
Generally easily sorted. I soldered the connectors, and have not had this problem arise since.
