Fault codes 18617, 01435 and 00933
Hi guys,
I scanned my other car Audi a3 2.0 tdi and it shows following codes.
after clearing codes, engine code fault goes away but after switch engine off and on again fault appears again.sometimes i do hear fan spinning at high speed even engine is not warm enough
Any thoughts?
Address 01: Engine        Labels: 03G-906-016-BKD.lbl
   Part No SW: 03G 906 016 FF    HW: 028 101 190 5
   Component: R4 2,0L EDC 0000SG  6337
   Revision: 12345678    Serial number: AUX7Z0DDFN20J2
   Coding: 0000072
   Shop #: WSC 06314 000 00000
   VCID: 6CD7E0F44F4C035EA7-8038
1 Fault Found:
18617 - Engine Coolant Temp Sensor on Radiator Outlet (G83)
            P2185 - 000 - Signal too High - Intermittent
             Freeze Frame:
                    RPM: 0 /min
                    Torque: 0.0 Nm
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 12.08 V
                    Bin. Bits: 00000100
                    Temperature: 72.0°C
                    Temperature: 40.5°C
Readiness: 0 0 0 0 0
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No: 1K0 907 379 K
   Component: ESP FRONT MK60      0104
   Coding: 0023174
   Shop #: WSC 06435 000 00000
   VCID: 3A7B16AC75986DEE65-806E
1 Fault Found:
01435 - Brake Pressure Sensor 1 (G201)
            012 - Electrical Fault in Circuit - Intermittent
Address 52: Door Elect, Pass.        Labels: 8P0-959-802-MIN1.lbl
   Part No: 8P0 959 802 E
   Component: Tuersteuerger.  H10 0030
   Coding: 0000048
   VCID: 3E731ABC69B041CE59-806A
1 Fault Found:
00933 - Electric Window Motor; Passenger Side (V148)
            005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Temp,is the temp sender or stat.or the lug has broke on the stat housing and jammed the stat.happened to me twice.
Save yourself trouble and replace both as you will use more coolant if you get it wrong.stats are cheap replace the o-ring too.ask for it because its a seperate part.use genuine too.
Good luck!
