Halogen Headlight Adjustment ?
Apologies if this has already been posted (I can't find it if it has), does anyone have a diagram showing which screws do what on the standard halogen headlights?
Think my dipped beams are a little low.
Fitted Philips xtreme vision 130 lamps but somewhat underwhelmed and want to try an adjustment.
Thanks in advance.
i fitted the same bulbs to mine & i wasn't impressed considering the cost over standard so I'm moving on to a 4300 hid kit
What's the legal stance on these? Not judging, just interested.
not road legal etc should having levelling system fitted with washers & you will have armies of keyboard warriors giving the chapter & verse of how this make you a ill caring motorist & stating mot laws - insurance issues etc.
in reality if you keep to a 4300 / 5k kit & use them with your headlights correctly adjusted as they are the projector type you will be fine they will look just factory fitted xenons that use 4300 bulbs.
Edited by *murph*
I've been running my 35W 4300K HID kit for 70,000 miles now and it's been great. Never flashed and two MOT's at two different test centres passed without issue.
is your the non can bus or can bus kit & did you code it with vcds so the car thinks its running zenons
Edited by *murph*
