Octavia Front tweeter failure
Hi guys just collected my 2010 vrs TDI on Thurs
Annoyingly I have noticed the drivers door tweeter is not working, is this a common fail on the mk2?
Would anyone have a p no for one so I can order.
ave you taken the door card offf to make sure its still plugged in?
Not as yet can't see why it would be unplugged, was hoping to get part ready so if it is bust I can swap it out and only need to remove the card once, (im lazy)
Hi Morry,
The tweeter wiring is "piggy-backed" off the woofer speaker so if you do take the door card off, it's worth checking that connector too.  The tweeter is heat staked onto the back of the door card so if you can get a replacement, you'll need to cut the old one out and glue the new one in place. Part number is 1U0 035 411E (confirm before you order).
Cheers,
Andrew
Cheers dude, I cant see why it would be unplugged, I will order one so if it is gubbed I can just swap it while door card is off for inspection.
