Driver side front door
Please can someone help me...I was reversing my fabia in darkness with the front door open when the door caught the grass verge and slammed against the front wing. The door is all creased so can someone please help on how to replace the door. It has also killed both front electric windows obviously it has pulled the loom and blew a fuse.. I will be very grateful for any help on fitted a new door..it's a 09 5 door mk2 1.4 tdi
Whoops, good effort.
If you have a look at the door hinges there are two 13mm nuts on the hinge itself. Remove the nuts and the check strap if it's still there (I doubt it) and the door lifts off.
