Retrofitting Superb Steering wheel to Octavia II Pre-FL
Hi,
I am planning to retrofit Superb Steering wheel to my Octavia II Pre-FL L&K. My current steering controller is 1K0 953 549 AQ.
I will pickup Superb Steering Wheel, Airbag, Airbag connector and steering controller 1K0 953 549 CD.
Have few queries
1. Will this be direct swap or i will need to play with wiring and coding?
2. Do I also need stalks?
3. Can i use paddle shift from new steering wheel?
4. Will i be able to use all buttons mounted on new steering wheel?
5. Will my current MFD controls mounted on stalk work?
6. Do i also need slip ring?
Need your expert inputs and suggestion on the same.
Thanks.
Edited by virgo79
  • 4 years later...
Hello virgo79
Did you ever sort this?
I’m currently in exact same situation, with exact same car/specs.
Thank you in advance!
