Help with bulb upgrade octy III
After reading all the stuff on here bout bulb upgrades I swap'd all my bulbs. Rear were led already so put in led no plate bulbs from superskoda. Then got orsam cool blue for dips and fogs. Got Phillips white vision for hi beam. Delighted with the result. Looks much whiter but not like your pretending to have hid. Much better vision in the dark compaired to standard. The only problem I have is when you have your dips on the drl is also on. It must run on half voltage or something it uses the hi beam bulb but it's very weak. I know you can turn off drl from car settings in stero but stays on when your using dips. Any ideas how to fix this.
Edited by EricG
Possibly with VCDS....might be worth posting in that section or the mk3 section.
