Skoda Fabia MK2 stereo change
I want to remove the Skoda Swing and put in my own single DIN stereo.
I have bought the following: http://1drv.ms/1R70Dic
I haven't been able to find a step by step guide online - but I have 2 quetsions based on what I have found
1 - I believe there may be a double aerial connector in the Skoda - does this mean I need an additional aerial connector of somesort?
2 - of the 2 wiring products O have, how will I connect the 2 loose wires?
The set didn't come with any fitting instructions!
Usually the two loose wires will be for ignition feed and permanent live
Is there provision in the block connector to clip them in
If memory serves me correct sony and pioneer feeds are opposite so you may need to look at the back of the set there is usually a wiring plug diagram indicating which wire is for which pin location and clip them in the relevant location
Hope that makes sense
Re the aerial I understand there is a single to double connection I would imagine it would work the other way aswell
