Power steering light
Hi guys, Just fitted a new battery couple of days ago, took car out today and power steering light (orange) is on, Turned wheel a few times and drove around but the light won't go off, Plugged code reader in and it shows no codes,,Any ideas?
Try and drive a good distance in a straight line. Mine goes off after about 200 yds
I drove about 4 to 5 miles today, and it didn't put the light off..
Thanks Mike, I've got VCDS  so i'll have a look at that, The car is in for an MOT next Friday, If i don't get this sorted out by then, Will it fail the MOT with the light on??      Just noticed in the paragraph above-------''Verify all of the WSS (Wheel Speed Sensor) values are plausible in the 03-ABS controller! We received feedback from both Mk70 equipped and MK60 ESP equipped (1K) Golf models with 02546 and 00778 DTCs that would not clear due to a faulty WSS''                     I've got an ABS fault on the rear offside wheel which has shown up as mechanical when i scanned the car which means Hub bearing with the ABS incorporated in it, Will this have anything to do with the power steering light coming on??
Edited by Doofy
Thanks Mike.
