VRS TFSI - Help with problems please.
Ive just bought my first sdoda - a vrs tfsi. It has a few issues  (which was reflected in the price) and im having trouble correcting them.
Some help would be great please.
Below is the VCDS scan.  Im near Eastbourne if anyone near can help it would be great.
1. It had a faulty abs sensor (rear right) thats been changed and the fault has gone but I have 01314 - Engine Control Module  013 - Check DTC Memory - what is this and where do I check it. I can't find DTS in the Engine Control Module, What do I need to do please?
2. 000256 - Mass Air Flow Sensor (G70)
               P0100 - 004 - Supply Voltage
Faulty MAF or wiring? wiring looks fine right back to ecu (ugh that evil anti tamper cage)
3. 00778 - Steering Angle Sensor (G85)
            000 -  -
Does this need to be basic programed, after a cruise control stalk was fitted?  Will it program with the above faults showing?
00120 - Outside Warning Light/Door exit Light Driver Side
            012 - Electrical Fault in Circuit
Not a real issue, but if its a common fault it would be good to put it right after the rest.
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
Address 01: Engine        Labels: 06F-907-115-AXX.lbl
   Part No SW: 1Z0 907 115 A    HW: 8P0 907 115 B
   Component: 2.0l R4/4V TFSI     0040
   Revision: 5BH16---    Serial number: SKZ7Z0F3974071
   Coding: 0203000318070160
   Shop #: WSC 28050 210 92292
   VCID: 336F0115522E491
1 Fault Found:
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 252710 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 21:04:02
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 67.0∞C
                    Temperature: 26.0∞C
                    Absolute Pres.: 1020.0 mbar
                    Voltage: 12.192 V
Readiness: 0110 0101
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No SW: 1K0 907 379 AC    HW: 1K0 907 379 AC
   Component: ESP FRONT MK60      0101
   Revision: 00H11001
   Coding: 0004738
   Shop #: WSC 73430 790 00000
   VCID: 73EFC11512AE091
1 Fault Found:
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No: 1Z0 907 044 H
   Component: ClimatronicPQ35 084 0305
   Shop #: WSC 00000 000 00000
   VCID: 3B7F29357A7E811
No fault code found.
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 AE    HW: 3C0 937 049 AE
   Component: Bordnetz-SG     H52 2002
   Revision: 00H52000    Serial number: 00000004665283
   Coding: 018C0F030004140000110D000000000000087F075C0000
   VCID: 6CDDDA694F90D69
   Subsystem 1 - Part No: 1Z2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 281106 022  0601
   Coding: 00055223
   Shop #: WSC 73430
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 T    HW: 1K0 909 605 T
   Component: Q4 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD0YE81K
   Coding: 0020788
   VCID: 3D7B272D646A8F1
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 BC    HW: 1K0 953 549 BC
   Component: Lenks‰ulenmodul 036 0070
   Coding: 0000042
   VCID: 74EDC20917A00E9
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No SW: 1Z0 920 912 C    HW: 1Z0 920 912 C
   Component: KOMBIINSTRUMENT VD1 1610
   Revision: V1610056    Serial number: SKZ7Z0F3974071
   Coding: 0003401
   Shop #: WSC 28050 576 92292
   VCID: 356B3F0D5C5A571
Address 19: CAN Gateway        Labels: 1K0-907-530.lbl
   Part No SW: 1K0 907 530 K    HW: 1K0 907 951
   Component: J533__Gateway   H04 0020
   Revision:   H04 02    Serial number: 030107F2001673
   Coding: 3D3F074007001303
   VCID: 2F670D65BE066D1
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VD1 1610
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN3.lbl
   Part No SW: 1T0 959 701 D    HW: 1T0 959 701 D
   Component: Tuer-SG         005 0954
   Coding: 0000756
   VCID: 387536394B48AA9
1 Fault Found:
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K2 909 144 L
   Component: EPS_ZFLS Kl.074 H07 1806
   Shop #: WSC 02069 000 90108
1 Fault Found:
            000 -  -
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Part No SW: 1K0 959 433 BT    HW: 1K0 959 433 BT
   Component:    KSG PQ35 G2  020 0203
   Revision: 00020000    Serial number: 00000000000000
   Coding: 99801A085283007F3F04850540085F96907CA0
   VCID: 830F11D5C20EB91
   Subsystem 5 - Part No: 1Z0 951 171
   Component: Innenraumueberw.008 4801
   Coding: 00000000
   Shop #: WSC 73430
   Part No: 1K0 951 605 C
   Component: LIN BACKUP HORN H03 1301
   Component:       NGS n.mounted
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN3.lbl
   Part No SW: 1T0 959 702 D    HW: 1T0 959 702 D
   Coding: 0000756
   VCID: 3973333D7042B31
Address 56: Radio        Labels: 1K0-035-1xx-56.lbl
   Part No SW: 1Z0 035 161 C    HW: 1Z0 035 161 C
   Component: Radio FO3       019 0034
   Revision: 00019000    Serial number: SKZ7Z3G0125385
   Coding: 0000402
   VCID: 2E591061B90C649
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN3.lbl
   Part No SW: 1K0 959 703 J    HW: 1K0 959 703 J
   Component: Tuer-SG         005 0907
   Coding: 0000144
   Shop #: WSC 73430 790 1012544
   VCID: 377735054656A51
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN3.lbl
   Part No SW: 1K0 959 704 J    HW: 1K0 959 704 J
   Coding: 0000144
Address 76: Park Assist        Labels: 1Z0-919-283.lbl
   Part No SW: 1Z0 919 283 B    HW: 1Z0 919 283 B
   Component: Parkhilfe 4-Kan H04 0020
   Coding: 0000001
End   ---------------------------------------------------------------------
