VRS TSI 2nd Water pump failure
We have had a Octavia VRS TSI for 2½ years. When the car was new it went in for it's 1000 mile check up to find that the water pump was leaking so it spent 3 days in the garage while they sourced and replaced it with a new one. It is now in the dealers again as it is losing coolant only to find that again the water pump is leaking and it requires a new one.
Now being from the world of engineering if an item fails once..ok. If the replacement part also fails...there is more to this than just replacing the failed part.
Is anyone having problem with the water pump leaking?
It's been a fairly common fault, but think your the first to have 2 go.  I thought they had altered a seal or something and fixed the problem ... Now I'm not so sure
it really depends on the failure mode. faulty part, incorrect installation. was the pump leaking from the shaft or the gasket?
