2010 Octavia VRS Engine airflow problem
Hi all, long time lurker but I can't quite find an answer to my problem with the search hence the post!
My Octavia is behaving a bit weirdly currently.
In chronological order:
Lambda sensor warning light on dash intermittantly came on and off
Engine 'lumpy' on idle with extra random vibrations almost like a misfire
Through the rev range @ low RPM car feels a bit un responsive at higher RPM it's fine
EPC and lambda sensor warning light came on on dash
Ran diagnostics and got the following fault codes:
04874 - Can't find out what this means anyone know?
08213 - intake manifold flap position sensor
00769 - coolant temp sensor engine outlet
I'm not quite sure how to solve it, has anyone had similar issues and how did you sort them?
Iain
Something like this?
004874 - Cylinder Disabling
P130A - 000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Mileage: 32377 km
Time Indication: 0
Date: 2000.00.00
Time: 04:25:26
After a little search it seems to point to a coilpack(s) being faulty. Seems to be quite common on VAG TFSI engines? http://www.golfmk6.com/forums/showthread.php?t=55549
Edited by hobbes42
Yes that would make a lot of sense, I had it in mind that the coil pack was likley to be an issue.
My train of thought at the minute is that I have the 3 commonish problems and I probably should:
Replace inlet manifold
Replace coilpack
Replace coolant temp sensor
Inlet manifold is expensive mind!
Iain
