Help! 1.8t TIP need advice!
Right normally the breather hockey puck (not sure what its called or what it does as it doesnt stop air from going either way) sits below the dv on the turbo intake, ive had to change them around to make things fit so that the dv is sitting below the breather, will this be alright???
I don't see why not.... both going to the intake pipe....
just my logic, I may be wrong for reasons I don't understand! lol..
How did you manage to do that?
It sits better with the forge tip without touching the toyosport fmic and i could then use the same hose just chopped up for the dv. I can only think that when the dv dumps the oily vapour it might get blown into the air filter?
That pipe sucks air, so going to the air filter is a little bit difficult. Why don't you use a catch can?
Thats the plan over time, just hard to get everything to fit with the fmic pipes!
