coolant leak
hi guys hope u can help seem to be loosing a bit of coolant each day and seems to be water on the gearbox only obvious place is the pipes that are under the y breather pipe anyone no what that part is called or have a part number is it a common fault to lose water from here any help is much appreciated as im not 100% sure where the leak is coming from
turned out it was the temprature sensor housing that was leaking
