Can't won't start.....help
Hi all been having issues with fuse 6 blowing.
Took cluster out to see if at fault and replugged and also checked under battery and undid fuse box in engine bay and now the car won't start. If I take battery off and reconnect it starts for 2 secs then dies. Then if I try again it just turns over.
I'm going insane here and can't work out wtf is going on .
Any help is appreciated !!
check the wiring, how did it go with the auto electrician?
Checked all the wiring Eddie and he didn't find anything so I was on the hunt for it now I'm regretting looking for it. Could it have lost sync with immobiliser ?
The immobilser is in three parts
Key + Cluster + ECU
if the cluster is happy with the key but communication is lost between the cluster and ECU then it will start and cut out after a couple.
Lost communication can be caused by several things
No Power
No ground
Break in CAN wiring
or faulty Module (instrument Cluster, CAN gateway or ECU)
Eddie would you be free for a chat ? If so can u pm ur number?
Just an update, Ecu has died nice bill coming my way
