Can you upgrade maxidot pre-facelift to facelift
I've got a 2008 Fabia 3 with maxidot but it's the older style, if I get my hands on a newer 2011 maxidot dash/clocks can they be coded in?
In a word.
No. (:
Ah, not good!
Never mind then. Thanks
Ah, not good!
Its abit more complicated than just plug and play even if its just swapping a cluster in a FL. theyre all different makes, although they look the same and need some intense coding in.
I think the canbus system is different on pre fl and fl too, amoungst other things.
Thanks again then, I won't bother if it's major hassle, not like it's improved that much, just a prettier picture :D
I'm tempted to buy a 2011+ mk2 with it having newer technology but then you have a worse engine 1.6 CR and then have to have a DPF as well...
I like the 2008 Fabia 3's since they have the 1.9 PD still.
No worries mate.
You could always go petrol? 1.2tsi is nice.
I know your problem though. Ive got a 1.9pd VW Transporter and fancy a new one, just dont want the new engines or a DPF. Its tough isnt it!
