What can be Retro fitted from the options list if looking at used cars?
Is there a definitive list anywhere that advises what can be retro fitted to the superb III with vcds if looking at a 2nd hand vehicle with some options missing?
SE L or L&K model does this matter?
I.e:  paddle shifts I read can be done with purchasing a new steering wheel and vcds coding.
So can any of the list below added or any others be retro fitted? (without or very little cost)
Traffic sign recognition
Media command
Smartgate
Phone box
Rear view camera
Park assist
Lane assist
Smart light assist
virtual pedal
Beam assist
SE L or L&K model does this matter? No but you will need the camera in the windscreen (std fit on the L&K) to activate some things
I.e:  paddle shifts I read can be done with purchasing a new steering wheel and vcds coding. When I sold my OE flappy paddle wheel (and subsequently fitted it into another L&K that was not ordered with flappy paddles) once coded identically to my car the paddles would still not work.
Traffic sign recognition Yes - requires camera
Media command ? I imagine will need hardware and coding
Smartgate ? I imagine will need hardware and coding
Phone box Will need hardware
Rear view camera Will need hardware and coding
Park assist Will need hardware and coding
Lane assist Yes but again requires camera
Smart light assist No, the lights are different
virtual pedal Will require hardware and coding
Beam assist Yes may need camera?
If most of the above are important to you then I would look only at an L&K, where most of the above is std.
And as well as parts and coding, add a significant drain on your Bank unless you can find the parts very cheap.
I'm finding it increasingly difficult to get vcds to make any changes to anything built 2016 onwards.
Everything seems to require background coding and parameterisation via ODIS and the changes just will not stick with vcds.
VAG getting wise to us freeloading VCDS users, but not directly mind, just making life that wee bit harder on each model release!
I.e:  paddle shifts I read can be done with purchasing a new steering wheel and vcds coding. When I sold my OE flappy paddle wheel (and subsequently fitted it into another L&K that was not ordered with flappy paddles) once coded identically to my car the paddles would still not work. Haven't given up on this yet. Found a specialist in Dunstable who I'll get to have a play and see if we can't finally conquer it. My cousin who has Skoda experience is convinced it will code.  ***UPDATE-07/12/16*** Switched from Octavia 3 buttons to Superb 3 buttons (with paddle shift ports-part no, 3V0 919 719B) and paddles now work. No coding required. Octavia 3 buttons are not compatible.
Edited by Devonshiredave
