Airbag fault 01221
Hello, just a quick one...
Whilst out and about today, my airbag warning light came on, along with an error message in the maxidot.
A quick scan with VCDS indicated the drivers side impact sensor.
On inspecting the wiring, I found a broken wire inside the rubber boot between the drivers door and the A-pillar... Once repaired and the fault reset, it has not returned.
I'm just posting this as I found another had experienced an identical fault, and thought it might be of use to someone else to know about it.... Especially before forking out on a new sensor.
Here is the offending wire:
http://tinypic.com/r/2dsnxih/9
I soldered mine with a couple of layers of shrink wrap to add strength.
Edited by VRSPhil
