horn not working, multifunction controls not working
So this morning it turns out my cruise and radio controls have stopped working (incdicators fine).
Having a gander online it seems as though the horn could be gone as well pointing to a faulty steering wheel control unit.
Sure enough.. the horn isn't working either. A £250 dealer part apparently.
Now.. I have an aftermarket stereo which was fine for a while and a little over a month ago was fitted with an aerial amplifier (without I'd had it for a little longer).
This amplifier is fitted to the power antenna. If I disconnect this amplifier the controls are still useless.
My octavia is a late model (54 plate) and uses canbus for a few things.
I haven't attempted a recent VCDS scan yet. Any thoughts on what it could be? Is it the 451 control unit? Should I attempt a VCDS scan with the aerial amp disconnected from the pwr antenna line?
I've read other threads but still slightly confused as to where the power for the amplifier should go and if it is safe to have connected to the head unit's power antenna.
steering wheel is part number is 1J0 907 487 A
Edited by bspman
The only issue with having the amplifier connected to the antenna live is they don't always stay live (powers up to extend the aerial and then goes off).
scanned with VCDS last night (I know, I haven't updated it just yet).
I'll post a dump but in short.. it's gone back to the mechanics as the majority of faults I have seem to be around things that they were working on. I have a feeling that there might be a wiring issue near something central as the problems seem to be intermittent for the ABS and the oil sensor.
More fun is that it looks like I can't use the high beams.
Thursday,11,August,2016,22:06:18:42399
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x86
VCDS Version: 15.7.4.1
Data version: 20160216
www.Ross-Tech.com
VIN: TMBCU41U148752663   License Plate: [redacted]
Mileage: 141400km-87861mi   Repair Order:
Chassis Type: 1U (1U - Skoda Octavia (1997 > 2011))
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 56 76
VIN: TMBCU41U148752663   Mileage: 141400km-87861miles
Address 01: Engine        Labels: 038-906-019-ASZ.lbl
   Part No: 038 906 019 KJ
   Component: 1,9l R4 EDC G400SG  5366
   Coding: 00002
   Shop #: WSC 31480
   VCID: 69DE313413DC7D76C9-4B20
   TMBCU41U148752663     SKZ7Z0D2474948
1 Fault Found:
18062 - Please check DTC Memory of Instrument Cluster
            P1654 - 35-10 -  - Intermittent
Readiness: 0 0 0 0 0
Address 03: ABS Brakes        Labels: 1C0-907-37x-ASR.lbl
   Part No: 1C0 907 379 K
   Component: ASR FRONT MK60      0103
   Coding: 0021505
   Shop #: WSC 31480 000 00000
   VCID: 326C9658AE8AFEAEB8-517C
2 Faults Found:
00283 - ABS Wheel Speed Sensor; Front Left  (G47)
            008 - Implausible Signal - Intermittent
            012 - Electrical Fault in Circuit - Intermittent
Address 15: Airbags        Labels: 6Q0-909-605-VW5.lbl
   Part No: 1C0 909 601
   Component: 31 AIRBAG VW51      0008
   Coding: 13105
   Shop #: WSC 31480
   VCID: 5DB615E4D79411D635-5142
No fault code found.
Address 16: Steering wheel        Labels: 1J0-907-487-A.lbl
   Part No: 1J0 907 487 A
   Component: Lenkradelektronik   0005
   Coding: 00118
   Shop #: WSC 31480
   VCID: 2F6A9F2CEDB8D346D7-5160
1 Fault Found:
01426 - Controls in Steering Wheel (E221)
            49-00 - No Communications
Address 17: Instruments        Labels: 1U0-920-xxx-17.lbl
   Part No: 1U0 920 911 J
   Component: KOMBI+WEGFAHRSP VDO V11
   Coding: 19414
   Shop #: WSC 31480
   VCID: 3664AA4812E2E28E94-5142
2 Faults Found:
00562 - Sensor for Oil Level/Temperature (G266)
            30-00 - Open or Short to Plus
01326 - Control Module for Multi-Function Steering Wheel (J453)
Address 19: CAN Gateway        Labels: 6N0-909-901-19.lbl
   Part No: 6N0 909 901
   Component: Gateway K<->CAN    0001
   Coding: 00006
   Shop #: WSC 31480
   VCID: 70E85C5030068CBE8E-5142
1 Fault Found:
Address 46: Central Conv.        Labels: 1C0-959-799.lbl
   Part No: 1C0 959 799 B
   Component: 3Y Komfortgerát HLO 0004
   Coding: 00259
   Shop #: WSC 31480
   VCID: 3664AA4812E2E28E94-4B38
   Subsystem 1 - Part No: 1U6959802D
   Component: 3Q Tõrsteuer.FS KLO 0202
   Subsystem 2 - Part No: 1U6959801D
   Component: 3Y Tõrsteuer.BF KLO 0202
   Subsystem 3 - Part No: 1U0959811D
   Component: 3Y Tõrsteuer.HL KLO 0202
   Subsystem 4 - Part No: 1U0959812D
   Component: 3Y Tõrsteuer.HR KLO 0202
End-------------------------(Elapsed Time: 03:58)--------------------------
Edited by bspman
  • 5 months later...
Just closing this thread off, I think a fuse had blown on top of the battery compartment for the electronic faults.
The ABS etc. was rectified as another faulty sensor fitted.
