New flap motor needed?
My MIL came on today and I had a few fault codes listed. To me they seem to point to needing a new flap motor but I'm wanting a second opinion.
A couple of thousand miles ago I had the manifold off and cleaned the inlet valves, I cannot remeber if the flaps were cleaned though as two of us did the job.
this is the fault codes from the car today, the evap one is an existing code that was there before the rest of them.
                Address 01: Engine       Labels: 06F-907-115-AXX.lbl
Control Module Part Number: 1Z0 907 115 A    HW: 1Z0 907 115
  Component and/or Version: 2.0l R4/4V TFSI     0040
           Software Coding: 0203000318070160
            Work Shop Code: WSC 20035 576 63608
                      VCID: 3365F94752C0B386591-8066
5 Faults Found:
001089 - EVAP Emission Control Sys
               P0441 - 002 - Incorrect Flow - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 0
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 169590 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 16:19:20
             Freeze Frame:
                    RPM: 776 /min
                    Load: 20.4 %
                    Speed: 0.0 km/h
                    Temperature: 66.0°C
                    Temperature: 21.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 14.478 V
012691 - Intake Manifold Runner Control
               P3193 - 002 - Open Stop outside of Valid Range
             Freeze Frame:
                    Fault Status: 01100010
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 170654 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 59.0°C
                    Temperature: 46.0°C
                    Absolute Pres.: 1020.0 mbar
                    Voltage: 12.319 V
001602 - Sensor Reference Voltage A: Circuit
               P0642 - 002 - Low - MIL ON
             Freeze Frame:
                    Fault Status: 11100010
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 170654 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 59.0°C
                    Temperature: 46.0°C
                    Voltage: 12.319 V
000566 - Manifold Pressure / Boost Sensor (G31)
               P0236 - 004 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 170654 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 12:23:44
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 59.0°C
                    Temperature: 46.0°C
                    Absolute Pres.: 1030.0 mbar
                    Voltage: 12.192 V
004248 - Intake Manifold Tuning Valve Position Sensor (G336)
               P1098 - 001 - Open or Short to Plus - Intermittent
             Freeze Frame:
                    Fault Status: 00100001
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 170663 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 12:51:08
             Freeze Frame:
                    RPM: 2495 /min
                    Load: 100.0 %
                    Speed: 66.0 km/h
                    Temperature: 81.0°C
                    Temperature: 24.0°C
                    Voltage: 14.351 V
cheers
