2006 SUPERB NOT BLOWING HOT AIR HEATER NOT WORKING
Hi,
I have a problem with my Skoda Superb 2006.
Basically it has stopped blowing out hot air.
I will mention on here exactly what work has been carried so not to waste your time.
New blower twice
thermostat changed twice
mechanic opened up the whole dashboard to see if any issues with heater matrix but couldn't find anything.
Changed the heater resistor
I have now ran out of ideas.
Can anyone suggest something please?
any help will be much appreciated.
Are the pipes from the engine to the heater matrix getting hot?
Has the mechanic used a recognised VAG diagnostics tool to investigate the heater controls?
Hi,
Yes the pipes are getting hot.
Mechanic has used Vag com but no faults coming up.
i would say V68 flap motor (doesn't always throw error in VCDS), if you get both pipes to matrix hot
do you hear buzzing noise when you change temp on climatronic fro 18 - 29 or back?
You can as well check movement of v68 in climatronic (please search for channel agenda...)
Channel, Displayed Value, Units
0, Program Number, Dig.
1, Interior Temperature, °C
2, Sunlight Intensity - Delayed 10, W/m^2
3, Sunlight Intensity - Instantaneous 10, W/m^2
4, Exterior Temperature - Delayed, °C
5, Exterior Temperature - Bumper, °C
6, Exterior Temperature - Fresh Air Inlet, °C
7, Vent Temperature - Footwell, °C
8, Vent Temperature - Dash, °C
9, Blower Voltage - Set Value 0.1, V
10, Blower Voltage - Actual 0.1, V
11, Temp.-Flap Set-Value, Dig.
12, Central-Flap Set-Value, Dig.
13, Recirc. Flap Set-Value, Dig.
14, Footwell/Defrost Flap Set-Value, Dig.
15, Motor Run Time, Hr.
16, Vehicle Speed, mph (km/h if not USA)
17, START_AP, Dig.
18, Recirc. Flap, Dig.
19, Compressor Error Code, See Appendix
20, PI_STELLMAX Ausbl-Reg., Dig.
21, INT_STELL Ausbl-Reg., Dig.
22, Epsilon Ausbl-Reg., Dig.
23, Vent Temperature - Actual, °C
24, Vent Temperature - Set Value, °C
25, Temp. Flap (-) Limit, Dig.
26, RMP Temp. Flap, Dig.
27, Temp. Flap (+) Limit, Dig.
28, Central Flap (-) Limit, Dig.
29, RMP Central Flap, Dig.
30, Central Flap (+) Limit, Dig.
31, Recirc. Flap (-) Limit, Dig.
32, RMP Recirc. Flap, Dig.
33, Recirc. Flap (+) Limit, Dig.
34, Footwell/Defrost Flap (-) Limit, Dig.
35, RMP Footwell/Defrost Flap, Dig.
36, Footwell/Defrost Flap (+) Limit, Dig.
37, Standing Time, Min. (255 = No Data)
38, Compressor-PWM, Dig. (0-200)
39, Evaporator Temperature - Set Value, °C
40, Evaporator Temperature - Actual Value, °C
41, Evaporator - I-Stell, Dig.
42, Evaporator - Epsilon, Dig.
43, Refrigerant Pressure bar
44, BiLevel Mix/Dash Vent Flap, Dig.
45, Motor Temperature, °C
46, Compressor Current - Set Value, mA
47, Compressor Current - Actual Value, mA
48, Compressore Current - Maximum Value, mA
49, Compressor RPM, 100/min
50, Radiator Cooling Fan Control Signal, %
51, Windshield Wiper Mode, Dig. (0=Off, 1=Int, 2=On)
52, Fdk-Correction wrt Wiper Mode, Dig.
53, Blower Voltage Correction wrt Wiper Mode 0.1, V
54, Part Number
55, VW-Number
