Driving Licence Categories
Bear with me in this one! Passed my test in 2000 so the following applies
"Category B - if you passed your test on or after 1 January 1997
You can drive vehicles up to 3,500kg MAM with up to 8 passenger seats (with a trailer up to 750kg)."
So I wouldn't be able to drive a motor home with a MAM of 3500kg as it says UP TO, however the following suggests I would if I stuck a trailer on the same vehicle then I woukd be legal?
"Category BE
You can drive a vehicle with a MAM of 3,500kg with a trailer.
The size of the trailer depends on when you passed your test. If you passed your test:
before 19 January 2013 you can tow any size trailer (it’ll say category ‘B+E’ on your licence)"
Any ideas? Looking at borrowing a motor home next year so just checking everything out.
Cheers.
On a cat B you can drive a vehicle up to and including 3500 without a trailer too. The 750KG is an additional trailer allowance over the 3500KG.
Where does it say upto and including? Everything I've seen says upto 3500 for a B whereas it only seems to say including when it's talking about the BE which doesn't make sense logically. Just want to make sure I have everything 100% correct shoukd the worst happen!
Up to a nominated figure I would certainly take as including that figure, otherwise 'less than' would be used, I would expect.
It's up to and including 3.5t. I doubt you'll ever get any camper van that is exactly 3500KG so it's acedemic. As for the trailer, you can tow a 750KG trailer if over 3.5t or any vehicle and trailer weight as along as it doesn't go over 3.5t. So on a 97-13 licence you can tow a 1.5t trailer with a 2t car.
Thanks for the replies. Just want to make sure I stay in the right side if the law.
