Help lol
My skoda octavia driving me nuts with constant beeping from dash and also lights on dash flashing it's the continuous bleeping driving me crazy though hand brake light flashing oil light flashing temperature gauge going up and diwn
Welcome to the forum.
Best go to someone that can find and fix the fault.
Maybe avoid any establishment with an Arnold Clark sign.
You should try to find someone with VCDS to scan the car and read the fault codes. Once you have the fault codes you can use this site to follow the guides on how to rectify them...
http://wiki.ross-tech.com/wiki/index.php/Category:Fault_Codes
You should check this thread too to see if there is anyone close to you with VCDS. Some beer tokens usually do the trick  :thumbup:
http://www.briskoda.net/forums/topic/224376-vcds-owners-map/
Edited by silver1011
As above, really need to check fault codes but perhaps also a sign your battery is on its way out. The Octy electrics can do funny things when the battery needs replacing.
Could it be the cluster
Could be battery, or alternator, or the sprague clutch on the alternator pulley if fitted. An auto electrician should be able to give a definitive diagnosis, as long as he gets any work resulting.
