Petrol smell on fast 70mph drive
As header ?
1998 1300
What did you try in order to diagnose the problem?
What do you suspect is causing the problem?
I am asking these questions because we are not wizards to guess what is the problem while you know the history of your car and you have full access to it. Do you call "1998 1300" enough information? Unless you want us to shoot meaningless in the dark because you didn't feel appropriate to share more data.
It is fuel injection basic model ,
a googling brought forth :
Check spark plug tightness
Go for fast run before checking for leaks before it evaporates
maybe leaking injector seals
of course fuel line tubing
Inlet manifold gasket, engine starts and idles OK
Fuel tank cap gasket
Fuel tank inlet pipe
Fuel tank breather.
Start with spark plugs tomorrow :)
Now where did I last see that Fire extinguisher I ask myself before a BIG BANG :)
Edited by iansmith
More thoughts.
Felicia is a reliable car in general. The most common cause for technical issues is the age of the car. This translates into corrosion of body parts, corrosion of connectors and wiring, and aging of various seals and gaskets.
Petrol smell => Leak somewhere => Bad seal/gasket/hose/line. Start looking under the rear seat for visual signs of leaks around the gasket of the fuel pump assembly. Follow the fuel lines up to injectors.
Let's not forget also that unburnt exhaust gases smell like petrol too. I would check the tightness of the exhaust manifold, exhaust pipes, and exhaust gaskets. One other thing, a bad gasket of the rear lid could 'help' drawing exhaust gases inside the cabin at high speed.
