Coolant - Roof rack
Hi,
My car was serviced last year before I bought it at a dealer's. Since then there's been no need to go near the coolant though now it's moved a little. - Just under the max marker. The coolant in it is pink - matches my eye's - but I've seen in the manual G13 purple.
Also Euro Parts have one  TRIPLE QX Purple (G13) (Ready Mixed) Antifreeze/Coolant 1Ltr for £2.99..
Can I top up with this ?
Another thing is Roof Rack. Is there one cheaper then £100 ? If it doesn't lock is there one I could easily put on and off.
Thanks.
Do not top it up.
They topped it to the MAX, it has bleed to the correct level,
There is MIN & MAX, there is no 'FILL TO THIS LEVEL',   If it drops more then it will need topping up, and have the Dealership do that while checking why it is loosing coolant after it set its level after it was up to operating temperature.
Use the Correct Coolant only when or if you do need to top up, you should not need to between services.
OK thanks.
