After market reversecamera
Hi all,
Is it possible to bye an after market reverse camera and install even if the car was not equipt originaly? I have vcds on hand.
Many thanks!
Yes
And do anyone have a tips on where to bye from?
I fitted one to my Mk2 vRS using these...
http://shop.mediaexponent.com/epages/GPL.sf/en_GB/?ObjectPath=/Shops/01042009-135970/Products/MX-REAR-VIEW-CAMERA-SKODA/SubProducts/MX-REAR-VIEW-CAMERA-SKODA-0023
https://www.kufatec.co.uk/shop/en/volkswagen/multivan-transporter/t5-until-2009/rear-view-camera-universal-interface-audi-vw-rns-510-315
Really excellent bit of kit & certainly worth the money.
Not sure if it's suitable for Mk3 but I'm sure if you contact them they'll advise (or maybe someone on here might).
Hi!
Thx for your reply! I have seen this type and it looks like it the same for mk3. But as I understand it has to be plugd in with the AUX?? I want to plug it in to the boot and not plug in by AUX. Is this possible?
Hi,
it is much easier on the MK111 as all it needs is the camera and a quick code with VCDS
I used a cheap clone one from eBay that replaces the boot release, I have gone down the wireless route but you can cable it if you feel like it.
There is a good thread on here with lots of info, but to be sure you get the correct camera take out your boot release and measure it as there seem to be different size holes on the same model of Octavia :sadsmile:
long thread but good info, I did not need to cut the hole mine was a perfect fit.
John
Edited by jjc
add link
Many thanks for the tip!!
10 minutes ago, jjc said:
Hi,
John
Many thanks for your time John
Thx again. Is it market on the handle or where do I check if its a 14/15? Thats a good tip to keep it clean:)
My old handle was 90mm by 33mm. The new handle is longer and wider.
Thanks everyone for your help! I hava a nother problem with my mediadisplay. If anyone has a tip there aswell i would be greatful! Please se my other post!
18 hours ago, jjc said:
Hi,
John
Hi John, I am not able to find it on ebay?! I want the oned that are in the boot release. I found only 1 but acc to seller it only works with wire to AUX and not with VCDS:( Do you have link to the one you bught?
Many thanks for all you guys time!
Do we know what versions of Columbus you can link a reverse camera to?  Mine is quite old at 2008 vintage
20 hours ago, jjc said:
Hi,
John
Many thanks John! Will do!
21 hours ago, jjc said:
Sorry to say that my handle is 9x3.5 cm "outside" so its to small :(
