Need help electric boot won't work properly
Hey guys, it looks like it is getting worst and worst, had this issue for the last two weeks, sometimes it work sometimes doesn't. Attached video with it. Just wondered if anyone had this issue before or knows where is the problem and or I would need to go to dealers?
Assuming on a 60 plate the car is well out of warranty then you'll likely be charged a minimum of £65 diagnostics fee (often refunded if you go ahead with their quote) at a franchised main dealer, so I'd find someone close to you with VCDS first to see if there are any fault codes stored that will help identify the fault...
My guess would be  the wires have fatigued  where the hinge is
