Weird indicator issue mot tomorrow (Monday)
Hi all well 1st fault after 7 years so not complaining but the mot is in the morning so would be good to at least give garage an idea if anyone can help.
So I go out in car tonight and bulb warning light lit, the car had blown a number plate light Friday which I changed thought I must be jinxed but went round car all light working but noticed a fault with the indicators the wing mirror ones work fine but the front and rear ones stay lit for about 15 seconds (timed by me )  and then start to flash its the same on the stalk and the hazards.
The direction indicators on the dash seem to flash faster than they should. I have taken bulbs out and swapped for other good ones and it makes no difference.
As I said mot tomorrow at my local place rather than hand it to him blind has anybody had similar so I can point him in the right direction.
Regards Roger
Edited by seriesdriver
Disconnect the battery for half an hour and re test it.
will do
That seems to have done the trick I just drove it back and forwards to turn the orange steering light off that had come on, all indicators working fine. Out of interest what does discontenting the battery reset ?
It resets the central electrics module that controls the indicators
Thank you very much for the help
Hi. Has the problem permanently resolved after the battery disconnect.
Hi it has not returned so far which is 10 days, passed the mot with no advisories. regards Roger.
