intake manifold gasket replacement?
I've got an ASZ engine (admittedly in my octy, but I figure you guys are far more active so I'd get a better response here).
I'm planning on cleaning my intake manifold. So my 2 questions are this:
1. What material is the gasket for the intake manifold made out of.
2. Would you recommend replacement of the gasket when I remove the intake manifold?
It was like a thin metal gasket when I changed mine, and for the (relative) pennies it costs to replace it's a no brainer in my book, although others may disagree.
As jars said they are made of thin tin, I have reused old ones without issue but if you can pick up a new one you might as well to save having to take it off again if it does not seal correctly.
Yeah, "tin" is a much better description than what I said :tongueout:
I was tempted to reuse the old one, but my time is worth a whole lot more to me than the few quid for a new gasket with no risk of rework removing the old one if it failed :)
Thanks for the replies. I've asked listers if they've got any (they have a thread on the forum somewhere).
I didnt use any of that stuff and had no issues at all. Just dont over tighten anything.  You can always nip up after.
Good you got a new Egr O ring. You should have no issues as all.
Thanks.. I know it can be a bit subjective, but how tight is "over tight" ?
Ooh now your asking... Torque figures will be about on here or tinternet, but they are no use if you dont have a torque wrench!
I nipped mine up to the first bit of resistance on the ratchet then added half a turn.  Im sure it was allen bolts if I remember and they go into an alloy head so its easy to strip threads.  Oh and I nipped them all up first then went back and added half a turn or so on each.
Looking about 20NM or around 18ftlbs for a torque wrench.
Edited by Graffiti
Got a torque wrench somewhere I think.
thanks for making me feel better about stripping heads! :sweat:
