No front or rear lights
I have vrs 11 plate I have no front or reef side lights head lights work but no rear lights all fuses in tact intereor lights work any help much appreciated
Have you damaged or got a faulty switch?
No no damage to switch
...And no warning lights/faults?
No warning lights got head lights but it doesn't show them on dash could it be a relay
So if you have the DRL's enabled (Switched on beside the fuses) do you have DRL's working?
If you put the Parking Lights on, Indicator down, key out is there one Side Light to the front & the same to the rear and a single number plate bulb lit?
EDIT.
Just read the thread where you say you 'Fitted Auto Light's',   might have been an idea to say that here in this thread.
So maybe now you need a Auto Electrician or a member here that knows 'Electricery'.
Best ask in the Auto Headlight thread as well.
Edited by Awayoffski
But if I put the auto lights back in then the lights all work fine except for the dash lights have lock and unlock the doors for the dash lights to come on
