Got AC Working
Well i finally  got the AC sorted had a local mobile mechanic and AC  guy out he tested the system no leaks so started to fill with gas tested the system and found the pump wasn't working ( i thought it was stuffed)   he had a look at the wiring and found the connector was loose  and it fired up so I could breathe again LOL finished re gassing and all was fine but the AC had no gas at all in it to start with, so car is all good now
What was the symptoms before you got it fixed?
