Crank Sensor Replacement
Evening all
I need to change the crank sensor on my PD170 VRS.
But can't find a simple guide.
Can someone point me in the right direction to a guide or a simple video please.
Its easy enough to do without a guide. Just locate it on the front of the engine towards the flywheel side, figure out what you need to remove if anything to gain access and then just swap it out with the new one.
Yep I get that about replacement just wanted to know location with a picture or diagram really
hi
  it behind the oil filter housing. you will have to remove it.
Waiting on delivery of the sensor.
Been told its behind the oil cooler not the filter housing and is a 4mm allen key head?
Not looking forward to changing it I know that much.
Anyone got an engine diagram link?
