Misfire
Afternoon all
Today I have developed a misfire under acceleration, if I was to plant my foot it would be instant but if I gradually increase speed it is fine.  I have done a scan with VCDS and below is what came back so any help would be greatly appreciated.  The only thing that has been done recently is a downpipe and sports cat put on but that was a week ago.
Address 01: Engine (CCZ)       Labels: 06J-907-115-CCZ.clb
   Part No SW: 1Z0 907 115 AF    HW: 1Z0 907 115 F
   Component: 2.0l R4/4V TFSI     0020
   Revision: AAH18---    Serial number:
   Coding: 0203000C18070160
   Shop #: WSC 73430 790 00085
   VCID: 79AE1F5005D8D34F6A7-802C
4 Faults Found:
008801 - Boost Pressure Control Valve (N249)
               P2261 - 000 - Mechanical Malfunction - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 0
                    Fault Frequency: 8
                    Reset counter: 255
                    Mileage: 97264 km
                    Time Indication: 0
                    Date: 2012.01.01
                    Time: 14:51:02
             Freeze Frame:
                    RPM: 1483 /min
                    Load: 10.2 %
                    Speed: 13.0 km/h
                    Temperature: 95.0°C
                    Temperature: 38.0°C
                    Absolute Pres.: 1020.0 mbar
                    Voltage: 13.716 V
000771 - Cylinder 3
               P0303 - 000 - Misfire Detected - MIL ON
             Freeze Frame:
                    Fault Status: 11100000
                    Fault Priority: 0
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 97324 km
                    Time Indication: 0
                    Date: 2012.01.04
                    Time: 10:26:53
             Freeze Frame:
                    RPM: 4433 /min
                    Load: 82.3 %
                    Speed: 89.0 km/h
                    Temperature: 95.0°C
                    Temperature: 26.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 13.970 V
004874 - Cylinder Disabling
               P130A - 000 -  - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 97324 km
                    Time Indication: 0
                    Date: 2012.01.04
                    Time: 10:26:55
             Freeze Frame:
                    RPM: 3891 /min
                    Load: 58.4 %
                    Speed: 104.0 km/h
                    Temperature: 94.0°C
                    Temperature: 27.0°C
                    Voltage: 14.097 V
004688 - Fuel Level too Low
               P1250 - 000 -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 97359 km
                    Time Indication: 0
                    Date: 2012.01.04
                    Time: 14:21:25
             Freeze Frame:
                    RPM: 3029 /min
                    Load: 29.0 %
                    Speed: 80.0 km/h
                    Temperature: 93.0°C
                    Temperature: 31.0°C
                    Voltage: 13.970 V
Many thanks
Before doing the downpipe,
or since when were the spark plugs last out, inspected, gap checked or plugs replaced?
Plugs were replaced around 6 months ago on last service
Unless you did them yourself i would get them out and check them,
as it will you need to check them anyway and then you know where you stand, then the next thing is ignition coils to check.
Ok will get checked tomorrow. Thanks for that
