Elephant's Trunk and Tailgate Wiring
Elephant's Trunk and Tailgate Wiring:
Don't worry or panic about the elephant's trunk, it's quite simple and works like this:
Gently peel the rubber trunk from both ends, it comes away rather like a grommet and exposes the plastic inserts at each end which engage in the holes in the bodywork.
With a tiny screwdriver or small wire hook with flattened end, release the holding catches and ease the inserts away from the apertures.
When replacing, refit the inserts into each end of the trunk rubber, then push/click back into the holes in the bodywork.  When you are doing some wiring, do remember to thread the wire through both inserts as well as the trunk!
Cheers,
Clive
