Yeti 2012 170 DPF air intake
At the front of the engine compartment in my Yeti 4x4 is what looks like an air-intake. Its lid was rattling around loose under the bonnet. Two questions -
   Has anybody else had this lid come loose? It really doesn't fit back on with a satisfying "click" so I'm thinking I may have to figure out some way to
   keep it in place.
   Should there be a filter of some sort in there? Else why would it have a (self) removing lid????
Just checked my 170 and it’s empty too - refit cover and forget is what I say!
mine has never come loose - two tabs hold it down on mine
Edited by sixer
If tabs broken could you use a cable tie to hold it together.
Primary air inlet, including water-entry trap.  Lid should clip firmly in place but, agreed, tie wraps are cheaper than new parts :nod:
Edited by Brijo
Thanks, chaps.
Tabs seem OK on mine, but it still won't sit down securely. Thought about a tie-wrap, but not easy to find a place to wrap it around.
Relieved to hear that I haven't shed a filter! But still puzzled as to why the lid comes off at all!
So that you can check for wild life.
Use Duct tape if zip ties are not suitable.
2 hours ago, MuddyLanes said:
Thanks, chaps.
Because the can collect all sorts of crap, from leaves to feathers.
And I suspect it would be a VERY expensive moulding to make in one piece!
Good point. And I'll check for leaves periodically!
Mine came off as well. The dealer tried to put it back on, but would not stay. I believe one of the tabs breaks off, and it is very difficult to see where it was. They then put on a new one, and it has stayed on since.
OK, thanks for the info. I'm going to see if I can get a tie-wrap around the body of the moulding.
