No BT display on cluster
Hi,
Fitted BT module in FL Octavia which has normal cluster (not full maxi dot cluster), I don't see any BT information on cluster (I believe non maxi dot at least display incoming call details).
Below is my Cluster, Gateway, Radio and Telephone log.
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb
   Part No SW: 1Z0 920 803 K    HW: 1Z0 920 803 K
   Component: KOMBI         H05 0405
   Serial number: 00000000000000
   Coding: 110800
   Shop #: WSC 73430 031 00999
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
   ROD: EV_Kombi_UDS_VDD_RM09_A04_VW32.rod
   VCID: 3C76B954B7BF43A696-8068
No fault code found.
Address 19: CAN Gateway (J533)       Labels:. 7N0-907-530-V2.clb
   Part No SW: 7N0 907 530 C    HW: 1K0 907 951
   Component: J533  Gateway H37 0614
   Revision:   H37       Serial number: 220111F2000961
   Coding: 351303
   Shop #: WSC 73430 790 00075
   VCID: 306E9D6463F7B7C63A-8064
Address 56: Radio (J503)       Labels:. 5M0-035-1xx-56.clb
   Part No SW: 1Z0 035 156 N    HW: 1Z0 035 156 N
   Component: BOLERO        003 0013
   Revision: -----13S    Serial number: SKZ4Z3P1104473
   Coding: 0D0004010101
   Shop #: WSC 17655 001 104857
   VCID: 3D70B450A4A54AAEA1-8068
Address 77: Telephone (J412)       Labels:| 7P6-035-730.clb
   Part No SW: 5K0 035 730 B    HW: 5K0 035 730 B
   Component: TELEFON       H09 1020
   Revision: 1B001001    Serial number: 00007669453479
   Coding: 0A01000000010110
   Shop #: WSC 73430 115 00055
   ASAM Dataset: UHVNA A01009
   ROD: UHVNA.rod
   VCID: 244661342F0F1B66CE-8070
Is there any coding which needs to be done for display?
Thanks.
The radio should display all details, since you have a Bolero. As far as I'm aware and have experienced, non-maxidot will not display any BT information.
It won't display
Maxidot is required
Ok.. Thanks.
