Help need with air Bag warning light
My Air bag warning light has come on and i have did a scan and the is the fault, however for some reason once i have tried to clear the fault it comes straight back on.  any help before i need to go to Skoda is  much appreciated.
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 T    HW: 1K0 909 605 T
   Component: Q4 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PC2305Z7
   Coding: 0020788
   Shop #: WSC 73430 790 00085
   VCID: 3D7749B66406C4F6B0B-8068
   Subsystem 1 - Serial number: 633  SME        6
   Subsystem 2 - Serial number: 6342MSME5A45283BK
1 Fault Found:
01221 - Crash Sensor Side Airbag; Driver Side (G179)
            010 - Open or Short to Plus - MIL ON
Check the wiring to the drivers door, you'll probably find a fault in the rubber between the door and car body.
Normal airbag precautions apply, battery out etc...
Pre-facelift only...
Sorry what does that mean?
There are two variants of the MK2 Octavia as it had a facelift in ~2009.
They are commonly referred to as a pre-fl and fl (pre-facelift and facelift) :)
Have you inspected the wiring yet?
Hi i have just popped the rubber off between the door and the main car and found a yellow plug with  yellow lead that is broken so i think i have found the fault. the main question is how do i pop the plug out of the main car body with out forcing it and making it worse?
