Throttle Position Sensor Problems
I have a 2013 2.0 tdi and some time age EML light started intermittently showing then stayed on all time, garage scanned it and found throttle sensor fault, replaced Throttle pedal with 2nd hand part and its just come on with in 500 yds of garage, i will take it back tomorrow, but i dought if the 2nd part is faulty to.Any thing else which can show this fault up please.
Car drives ok with no problems and pulls well .
Edited by andytax
  • 2 years later...
I am having the same issue.
That is because the sensor in question is the one that measures the angle of the motorised throttle valve in the intake tract, they have replaced a perfectly serviceable part and left you with the fault.
You are the second person in as many days that has been relieved of their hard earned for a throttle pedal sensor by a garage that cannot even read a fault code properly.
The good news is that the throttle valve most likely only needs cleaning unless the gears have stripped.
The bad news is that the garage would not tell you that.
Edited by J.R.
