Help on RNS315
Can somebody clear something up for me.  I have just bought a bluetooth microphone to retrofit to my MkII Fabia VRS.  If I bought the RNS315 below would i still need to buy a bluetooth module or would it be ok with it saying bluetooth built in.
https://www.ebay.co.uk/itm/301827598463?_trksid=p11401.c100711.m5036&_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20170110121435%26meid%3D73b34d8847634b94b0cfad25bbd2cd72%26pid%3D100711%26rk%3D1%26rkt%3D2%26sd%3D301827598463%26itm%3D301827598463&ul_noapp=true
Thanks in advance
Morning, if it already has Bluetooth built into the unit then you don't need a module.
Brilliant, presumably I would just need somebody with VCDS to code in bluetooth and turn by turn on the Maxi Dot display
Yep that's the one.
you'll need a gps antenna for the sat nav too, they're not expensive.
You know where the mic goes right? In the interior light :)
Yeah i've ordered a genuine microphone and cable with the green plug at the end.  Am I right in assuming there is an open slot in the quadlock that the microphone to plug into?
Most of the units on ebay sell with a new GPS antenna but like you say it isn't that expensive to buy one anyway.
Last question on this one i swear!
Would there be any issues with functionality with installing this into my 2011 VRS if say the unit came from a 2014 vehicle.  I had read somewhere about the newer units using different protocols which could cause some issues.
Yep there's an open slot and it can only go in 1 way.
I have a 2010 vRS and my unit came from a 2014 or 2015 vehicle and that worked fine so that shouldn't be a problem :)
Brilliant, did you get it coded on VCDS by a local Briskoda member or did you have to take it somewhere to be coded?
A bought it off a member from here and he coded it for me since he was in the area but I've coded a few in myself. Most only charge beer tokens :)
