Washer pump fuse
Hi I have a 2017 Octavia and a 2017 Fabia.
The washer pump on the Fabia stopped working I dutifully checked the fuse which seemed ok. I then took it to the dealer who told me it was the fuse after all.
I now have the same issue in my Octavia the fuse seems ok but can someone confirm which fuse I should be checking before I contact the dealer again?
Also I suspect this is due to washer fluid freezing causing the fuse to blow when the pump is activated.  This hasn't been an issue in any of my previous cars. Am I missing something, obviously the washing fluid has anti freeze in.
The question is has it got enough anti freeze in ? At -6 You need a lot more in than at -1
The fuse should be labelled in your manual but I can't find it lol nearest I could find was 36 headlamp washer.
Thanks 42 is down as washer but it hasn't blown and hadn't on my Fabia either.
