P176F00 "Clutch 2 closes unintentionally", returns after clearing. Sensor or mechatronic?
Hi all — car's currently with a Skoda independent specialist here in Bristol, and I wanted to sanity-check with the forum while they dig in.
Car: Octavia RS 2.0 TSI Combi (245 PS), MY2022, 7-speed wet DSG (DQ381 / 0GC), 65000 miles. Service history: full Skoda / independent — DSG oil + filter service not done.
What's happened:
  • got the alert “ gearbox in emergency mode. No reverse possible”.
  • Breakdown technician’s scan showed two codes: P27F500 (selector lever lock, Park position) and P176F00 (Clutch 2 closes unintentionally).
  • P176F00 has a VAG TSB: if it's sporadic with a frequency counter of 2 or less, you clear and test drive; if it returns or is static, it's guided fault finding.
  • Cleared the codes, drove ~5 min, and P176F00 came straight back with the counter now above 2. So it's persistent, not a one-off.
Questions:
  1. Anyone had P176F00 on a DQ381 — root cause and fix? Clutch pressure sensor set, mechatronic, or clutch?
  2. Did a DSG oil + filter service ever clear it once the code was logged, or wishful thinking?
  3. Anyone managed to get Skoda to cover a DQ381 mechatronic as a goodwill job at ~4 years old?
Thanks.
Anyone would know how to source an used mechatronic? thanks
I can't answer your question but this might help
And what do you expect after 65,000 miles without an oil and filter change? The manufacturer claims 80,000 miles without service—lol, that’s advice for the gullible. As a rule, transmission fluid in these models should be changed every 60,000 km (35,000 miles). Sure, the service schedule says engine oil gets changed every two years... lol. Of course, the engine will last as long as the warranty holds, but afterwards—you'll be left wondering, "What was I thinking?" For RS models—and especially TDI models—the engine oil should be changed every 10,000 km, and the transmission is a whole other story. RS models are driven much harder and pushed to the limit—you really need to change the transmission fluid every 35,000 miles.
