1.2TSi 110PS Gear Ratio's
Hello All Tech Nuts
I have a excel spreadsheet that can work out speed at revs as long as you know the gear ratio's, tyre/wheel sizes and of course final drive ratio.
I would like a confirmed gear ratios for a 2015 1.2TSi 110PS engine as i have a Fabia Monte Carlo 1.2TSi 110PS hence the motivation.
What I know is:
1st Gear   =  ?
2nd Gear  =  ?
3rd Gear  =  ?
4th Gear  =  ?
5th Gear  =  ?
6th Gear  =  0.610
Final Drive = 3.930
What will be the ratio's for 1st through to 5th gears ?
Any Help will be appreciated, if a source material can be added that will be fantastic.
SlightlyQ
Hi SlightlyQ,
as per "ŠKODA Fabia III Vehicle Introduction Part I Self-Study Programme":
02U (MQ200-6F) 1.2 TSI/81 kW
Final drive (permanent gear): 3.93
1st Speed Gear: 3.62
2st Speed Gear: 1.95
3rd Speed Gear: 1.28
4th Speed Gear: 0.93
5th Speed Gear: 0.74
6th Speed Gear: 0.61
Reverse gear: 3.18
6 hours ago, yankarinRG said:
Hi SlightlyQ,
Reverse gear: 3.18
Thank you good sir, that is amazing....
SlightlyQ
  • 1 year later...
Hi guys,
How did you get info for gear ratios? I have a 2017 Mk3 1.2Tsi 90Hp with 5 speed manual, how could I get info of gear ratios and final drive ?
Thank you in advance :)
@FodorB3l4
Welcome.
You use a Search engine / Google,  or someone that can might be along and having found them post or link them for you.
